External reference search
In the external reference search order, the second priority for SW is to look in a folder specified in Options. Both the Help file and the 2009 Essentials manual say that this is found under File Locations-->Folders. The problem is that "Folders" doesn't exist in the File Locations list. I see an item called "Search paths." Is this it? Thanks.
RE: External reference search
