cutting aluminium
cutting aluminium
I am not a machinist but in my work as a mechanical engineer I have to do some building which involves milling and turning and cutting.
Of all the materials I work with aluminium alloy sheets and plates ( eg AlMgSi 0.5 F22/6060 or HE30) gives most problems with poor finish and clogging of cutters, drills, hacksaw blades.
I am mainly using HSS toos without coolant.
Could someone give advice on speeds or cutter types for general purpose aluminium.
RE: cutting aluminium
For everything else, just turn the speed _way_ up.
E.g. when drilling aluminum, if you've got the speed and feed high enough, the drill will literally spit small, gray, almost granular, chips out of the flutes, even on a deep hole.
Reduce the speed by half, same conditions, and you get birds nests of stringy chips, and you break drills in deep holes.
Mike Halloran
Pembroke Pines, FL, USA
I find a quick squirt of WD-40 works well with all aluminium alloys for the odd milling and turning job where the proper soluble oils are not available in small quantities and won't cause rust if it gets under a machine vice. If you get files clogging up (pinning), rub some ordinary blackboard chalk on the teeth.
As re TapMagic, make sure the one you get is compatible with aluminum.....read the label.
Agree with not going to the extremes on speeds/feeds. SFM figures are for ideal conditions.
Get a chart and start at the low end. I made one up using Excel many years ago for shop use.
Speeds / feeds - I've found that super high speeds on aluminium tends to distort the metal and lead to poor finish, thus I'd take the speed/feed up by a given level. I tend to benchmark the speeds/feeds for steel in my head, then if I work with other materials, I'll speed it up / slow it down from that.
Hope that helps
Larry
Larry Coyle
Managing Partner
Cylinder Head Engineering, LLC
CNC Porting
De Soto, KS 66018
bridgeport vs. Morie Seiki (Rigidity?)
single spindle vs ?
2 flute vs. multiflute
Milling cutter vs fly cutter
Must use some type of oil or coolant to flush out chips & keep tool cool.
Roughing cycle~ slower SFPM but deeper depth of cut & increased feed.
Finishing Cycle~ Higher SFPM but smaller depth of cut & finer feed.(Take light cuts at high speed) better finish.
Use the recommended feeds and speeds from the Internet.
Powerhound, GDTP T-0419
Production Manager
Inventor 2009
Mastercam X3
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
Why aren't you using coolant?
Production Manager
Inventor 2009
Mastercam X3
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
Use as much RPM as you have... can't have too much RPM for finishing on aluminum. If you're finish profile-milling, use 3-flute cutters... should be obvious why. Regardless the cutter, always climb cut for best finish. If you're doing this on conventional machines, leave as little stock as necessary (.005-.010) and make sure you lightly pre-load your gibb-locks to prevent the machine from running away into the cut.
For roughing, back the speed down to an RPM where torque is highest, use 2-flute cutters. The rules change a bit depending on the machine, cutting strategy and volume of coolant you can get to the tool.
Use cutters specifically designed for machining aluminum alloys. HSS is fine for one-offs and projects but I'd use carbide for any kind of production milling/turning. TiN coated HSS will also help in preventing galling at the cutting edge... all that more important if coolant is sparse... ie, spray mist.
One of the key characteristics of aluminum (Al)particularly the low silicon (Si)content alloys is the tendency of the material to weld to the tool - so called built up edge or BUE - the addition of an EP (extreme pressure)lubricant at the point of cut will help a great deal - a chlorinated EP is the most effective EP package available for AL.
Assuming that your machine does not have flood coolant I would look at applying a good chlorinated soluble oil (start at about 7%)with a good quality spray mist unit - I suggest that you look at using the coolant concentrate (as it comes from the drum) to provide high levels of both hydrodynamic an EP lubricity of operations like drilling, tapping and reaming - this will work better over all that using a special taping compound as the parts can be washed off with water and the resulting mixture used in the spray miser.
A.R. "Andy" Nelson
Engineering Consultant
anelson@arnengineering.com
