Oversizing Standard Flange Hole Size
Do you know of a more convenient/practical method(s)to verify that a NPS 24 Class 600 slip-on reducing flange (material ASTM A182; 1 1/4 Cr- 1 1/2 Mo) complies with the requirements of ASME B31.3 sections 304.7.2 (Unlisted Components). - Thank you in advance -
RE: Oversizing Standard Flange Hole Size
Does a larger bolt hole size kick the flange out of a listed component (where one could use Sec8Div1App2?) into an unlisted component (that might require FEA?)?
