NFPA 79:external power vs estop string
From NFPA 79, 13.2.4 requires that orange is to be used for conductors that do not de-energize when a disconnect is switched off.  How does that reconcile with a production line that has multiple machines but only one central estop string.  Do all of the estop conductors have to be orange in the various line components?
Wallowitz
RE: NFPA 79:external power vs estop string
If power remains on them after the disconnect is switched off, yes.
David Baird
Sr Controls Designer
EET degree.
Journeyman Electrician.
