Problem with some definitions for Flare stacks and total pressure drop
Hi everybody!!!
Can anyone tell me the real meaning of these concepts:
-Double Dual Thermocouple (it is for Pilot)(It means that it is "2" thermocouple or what????
-Noise Maps
These correspond to flare topics.
And how can I calculate "Total Pressure Drop" on a flare stack?, I have total height and diameter but I need to calculate total pressure drop.
Thank you so much.
Saver
RE: Problem with some definitions for Flare stacks and total pressure drop
probably 2 x thermocouples packaged together.
Noise maps are plots of dB sound levels eminating from the burning flare jet.
You'll also need to get a similar radient energy map.
To get the pressure drop, you'll need the maximum flowrate and pressure losses factors across all components.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
