Tumbling Test for Plated Parts?
I am trying to compared the durability of various grades of both Phosphate and Zinc plating. We (Engineers) were thinking that besides the ASTM B117 Salt Spray Test that we should do a test were the parts are tumbled and then evaluated for corrosion resistance because the bolt nut assym in question are often handled roughly.
Does such a tumbling test exist?
Thanks in advance.
Thanks in advance.
RE: Tumbling Test for Plated Parts?
In our experience it is a go / nogo deal. If the plating stays on in testing then it will stay on in use.
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
Good engineering starts with a Grainger Catalog.
What aggregate did you use in the tumbler?
On the other hand, there are standardized tests for other damage types, like scribing to the base metal, gravel chipping, etc.
ASTM D 1654 Standard Test Method for Evaluation of Painted or Coated Specimens Subjected to Corrosive Environments
For gravel chipping:
SAE J400 Test for Chip Resistance of Surface Coatings
The Zinc coating seems to be tougher than the Phosphate coating. We are now performing the ASTM B117 Salt Spray test.
