Could somebody help me with this program?
After running this program in g95 and intel fortran for windows I keep getting the same two errors
use_scat_daily_example.f(29): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: (
* ) :: , + . - %% : . ** / // .LT. < .LE. <= .EQ. == .NE. ...
CALL GET_SCAT_DAILY_V03 (filename,mingmt,windspd,winddir,scatflag,radrain,IERR)
GET_SCAT_DAILY_V03.F(1): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: * <IDEN
TIFIER>
        SUBROUTINE GET_SCAT_DAILY_V03(FILENAME,MINGMT,WINDSPD,WINDDIR,SCATFLAG,RADRAIN,IERR)
programs are attached
iigp
RE: Could somebody help me with this program?
change the file extension from .f to .f95 as this will remove the 72 line character limit (which looks like the cause of your error messages above)
However your source code has several other non-standard things going on, which I'm sure g95 will list for you!
Many thanks Johnhors
The source code runs fine now.
Iiigp
