5 axis machine
5 axis machine
5 axis machine
What are the best 5 axis machines on the market these days?
Thanks for any input.
Specialist 3 & 5 Axis Machining
http://www.midlandalloy.com
RE: 5 axis machine
Turning only?  Turning + grinding?  Front only or front & back working capability?
RE: 5 axis machine
It also depends on what you are machining.  Check out FIDIA at
Larry Coyle
Managing Partner
Cylinder Head Engineering, LLC
CNC Porting
De Soto, KS 66018
RE: 5 axis machine
define size and shape, material, cutting torque needed of part.  Five-axis can be done in two ways; tilting the part or tilting the tool; depends on part characteristics. Fidia and others tilt the head/tool for larger more cumbersome workpieces. Other machine like DMG, have tilt tables.
RE: 5 axis machine
When you can tilt the tool, the workpiece is usually in a stationary position.  In other words, the tool revolves around the part.  This has given me the ability to have a more accurate and better surface finish.
larry
Larry Coyle
Managing Partner
CNC Porting
De Soto, KS 66018
RE: 5 axis machine
Matsuura, Mazak, Mori seiki
RE: 5 axis machine
Dicer, are you saying that those machines have an articulting head?
Larry Coyle
Managing Partner
CNC Porting
De Soto, KS 66018
