Dribble rate sensor.
I'm finding it extremely hard to find a flow meter good for the area around the 0.01~0.2 gallon/minutes(150psi). [~6 fluid oz/min]
I've searched high and low.
I'm amazed places like GEMS have not addressed this region.
I'm starting to think I have to design one... Right after I kill myself.
~$200 limit.
Names?
~$200 limit.
Names?
Keith Cress
RE: Dribble rate sensor.
Water. Tap water...
Lots of those turbine meters out there. They just all krap out below 0.1gal/min. If they'd just make one fifty percent smaller we'd have it.
Keith Cress
http://
This is a bit like a rotating multi compartmental bucket. In flow is directed into a a compartment to one side of the axis of revolution.
As it fills, it rotates the shaft until the next bucket is lined up and the first can drain away.
It might be similar to this: http://www.freepatentsonline.com/4613058.html but without the pics couldn't say.
It is a bit like this gas meter:
http:
I think they were originally designed for some very slow process operations like condense flow from an evaporator or distillation column.
JMW
www.ViscoAnalyser.com
JMW
JMW
0.3" (8mm) 0.009 to 6.6 gpm
Roy
0.6 ft/sec at 0.01 g/m
3.75 ft/sec at 0.2 g/m
This is for embedding into a product that will likely be plumbed with 1/8" or 1/4" stainless steel tubing.
jmw; Those Flow Technology sensors look really nice. Not even their reps have prices... Doesn't bode well.
danw2; Thanks for the Dwyer link. They have a nice unit that's about $250 that could work. I wish I could dial down the price by dialing down the accuracy. I'm happy with about 2~3%.
Keith Cress
So, back to a low cost meter...you didn't say if it is flow total or flow rate but if I assume flow rate, try a variable area flow meter.
These can be had for a few dollars if you don't need too great an accuracy.
Try Platon or Rotameter (now part of Emerson I guess...oops! Emerson appear to have discontinued the Rotameter VA meters.... and they were a top quality product...) so do a search for Variable Area meters.
JMW
A Search for "low flow peristaltic pump" produces plenty of results, some with prices.
Now if I can just find an electrificated one.
FrancisL; I'm afraid a peristaltic pump wouldn't have the lifetime needed since this thing will run thousands of cycles/day. Aren't PPumps really hard on their wetted element?
Keith Cress
Solenoid type metering pumps can have a very low overall flow rate.
There are other very low flow metering devices such as Clarkson feeder.
Perhaps give us some more details on what you are trying to do.
Roy
Perhaps that is a red herring, but the reason I brought it up was that many years ago I was involved in a project which needed a very low flow the speckler - for spraying ink onto mini eggs! And the solution we found was a peristaltic pump.
As ever a better understanding of the process is needed, for example what is the water for and what does actually set the flow rate.
Here's a link. And no, I have no affiliation.
http://www.brooksinstrument.com/category11.asp
Pay a little extra for the integral valve and you can regulate the flowrate from the meter.
The next corporate shenanigans lead them to Emerson and on Emerson's Mobrey site you will see them under discontinued products.
JMW
13 - 100 ml/m K-32703-50
50 - 500 ml/m K-32703-52
For US$240 + US$120 for a display
www.colepalmer.com (800) 363-5900
page 718 of the 2007/2008 catalouge
I doubt you will get the 20:1 turndown you ask for in a cheap meter.
Roy
Roy
roydm; those Cole Palmer units look exactly like the Dwyer units I saw. I kept thinking "Cole-Palmer" but never actually looked because I figured the mark-up would be punitive! Interestingly their prices for the Dwyer units are about $50 less(!!) than the discounted prices Dwyer offered.
This is for a commercial drink dispenser machine. Hence the cost sensitivity.
Keith Cress
JMW
ht
Spec sheet says low end flow is 0.014 oz/sec.
This one here fits your flow range pretty well, but the construction looks higher cost than the one above:
h
Dan
The response, "Oh that's right. Never mind."
danw2; That first one looks the part! The pressure is even right. I will hunt down a price on that. Thanks.
Keith Cress
Also check out http://
It looks cast/machined. It even has a hall switch in it.
I'm amazed. It's Italian.
But! As I woke up this morning it dawned on me that this whole thing is being driven by an (inside) gear pump. Maybe someone can tell me if they're considered to be enough of a positive displacement pump to be able to count the revolutions and infer the flow indirectly.
Keith Cress
PS: PD meters and PD pumps can employ very similar geometry but one is motorised to drive the fluid through the pipe and the other is driven by the fluid flowing through the pipe.
JMW
"But! As I woke up this morning it dawned on me that this whole thing is being driven by an (inside) gear pump"
As I said before, "As ever a better understanding of the process is needed, for example what is the water for and what does actually set the flow rate."
A nice little diagram would have helped a lot. It still would.
What accuracy are you seeking? A simple rotation counter on your gear pump might be all you need. In fact you might not even need that if you can derive the flow some other way.
www.controldraw.co.uk
Francis
I'm not at liberty to say more than this is a drink dispenser that runs between 60 and 140PSI with a time varying profile thru a nozzle.
I control the pump via motor speed and I have pressure feedback. If I'm controlling the effect at a nozzle in a pressure system, I can't really see what I'm going to do with flow. Don't I focus on the pressure profiles? Flow is too slow and too inaccurate for controlling to a repeatable output profile when the nozzle varies with time.
It would seem flow would be much more valuable in the case where I have an unrestricted flow between, say, two tanks and I want to profile that or totalize it, another words, flow that would see little pressure variation.
This is rather like an electrical system where you need a specific voltage profile. You wouldn't add a resistor and convert to current feedback if voltage does the trick.
I'm adding flow here more as a check, as back to the voltage regulator, you might look at the current to limit over current. So the more I think about it the more using the pump as a flow meter seems to fit the bill.
No diagram needed. Pump-> Flow meter(or not)-> pipe -> pressure sensor-> nozzle.
Keith Cress
JMW
Since I have a flow sensor in hand I'll use it also and have cage fights between the two!
Keith Cress
