NX5.0 licensing
NX5.0 licensing
Hi Guys
I had a problem, with the UGS licensing.
So i want to reinstall the UGSlicense.
But the problem now is I can't install/repair or remove UGSLicensing. Has anyone had this problem before?
I've un-installed NX5. , but still can't get rid of UGSLicensing.
Greetz,
and thanks in advance.
Tom
Greetz,
Tom
RE: NX5.0 licensing
hpe it helps
RE: NX5.0 licensing
thanks for your answer,
but it doesn't work.
the uninstaller (@"Control Panel", "programs")
starts, but then a error apears and says "Repair will not work. You must remove and reinstall".
The problem is, I want exactly what it says.
Hope there is a answer.
Greetz, Tom
RE: NX5.0 licensing
Maybe check again under the Windows "Control Panel" using "Add or Remove Programs". There are separate installed products for "UGSLicensing" and "UGS NX 5.0" you may only really have needed to uninstall the former.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
RE: NX5.0 licensing
I am running Vista.
But only what is left in "add or remove programs".
is UGSlicensing.
tom
RE: NX5.0 licensing
Now try to remove in add/remove progs
RE: NX5.0 licensing
I have looked at services,
but there is no UGSlicensing.
So i guess the service is stopped already.
Greetz Tom
RE: NX5.0 licensing
If it's not displayed, I'm not sure why you cannot remove it.
RE: NX5.0 licensing
so I put it in a command bar.
There is nothing from UGS.
so there isn't a service left.
tom
RE: NX5.0 licensing
Larry
Larry Coyle
Managing Partner
Cylinder Head Engineering, LLC
CNC Porting
De Soto, KS 66018
RE: NX5.0 licensing
try this....remove any windows variables from UGS...stop all processes and than it's should be ok to remove it...
The problem is, you can't remove the licesing becouse it is still active in windows processes.
Regards, Tadej
RE: NX5.0 licensing
I checked at the processes and services,
but find nothing from UGS.
Greetz,
tom
RE: NX5.0 licensing
Ben Loosli
RE: NX5.0 licensing
There are no processes named like that.
Tom
RE: NX5.0 licensing
To go any further with removing the last vestiges of something you've installed you'd have to look to delete any directories associated with the original install and then to make 100% sure hack the registry to remove all reference to the product. This latter move involves taking a risk for which I can't identify the gain so maybe we ought really to come back to your the problem and start again.
Apart from anything else if you've a legal license you should be able to call your local help desk. Licensing is a common problem and it would be rare that we here would be more or better equipped to assist you.
Best Regards
Hudson
www.jamb.com.au
