Fracture Toughness Source
Does anyone know of a good resource for fracture toughness data for induction hardened material (in particular 52100 and 4140H)? All of the research I have conducted thus far had fracture toughness data for quench and temper material only.
Thank you!
RE: Fracture Toughness Source
Induction heating is just a method for changing the temperature in a metal, so that certain microstructures can be developed.  If the final microstructure in 4140H is martensite that has been quenched after induction heating and then subsequently tempered at a low temperature, then find fracture toughness data for 4140H that has been quenched and tempered to a similar high hardness condition.  Fracture toughness does not apply to an entire part, it applies to a microstructure, and therefore will be different if the case and core properties are different.
Thank you for the reply TVP.
I understand what induction hardening is and that the fracture toughness is dependent on the microstructure.  My  issue is that I haven't been finding fracture toughness data for the high surface hardness that our parts are specified to have (55 HRC).  I'm not so concerned with the toughness at the core.
NLJ,
I've been told that the best source for fracture toughness and fatigue crack growth rate data is a series of papers by Michael Hudson, published by the Int'l Journal of Fracture:
    Vol. 14, 1978, pp. R151 – R184.
    Vol. 20, 1982, pp. R59 – R117.
    Vol. 39, 1989, pp. R43 – R63.
I myself have also had trouble finding values for plain strain fx toughness (K_1c) to use in design work.  Textbooks that I find useful are:
    Dieter – Mechanical Metallurgy
    Hertzberg – Deformation and Fx Mechanics
    Nat'l Materials Advisory Board (NMAB), Report 328 (free on google books) Figure 1 shows ranges of K1c for various alloys in a lab environment (ambient temp, no corrosives).
To state the obvious in case you cannot find published values, a mechanical testing lab can run ASTM E399 for you.  Valid plain strain results should be easy with such a high hardness.
As you probably know, for typical alloy steels
    55 HRC = UTS apprx 300 ksi = pretty crappy K_1c
With hardness vs fx toughness it's a case of not being able to have cake and eat it too, unless you go with a more expensive material, e.g. AF1410 or maraging steel.
