SAFE v12 punching shear
Hello guys,
I have a model of a flat plate, with a couple of shear walls on the perimeter. I have trying to verify the punching shear of the columns but for some reason I don't know, SAFE won't calculate the punching shear on the perimeter columns ("N/C" result).
When does SAFE stop calculating punching shear? If the columns are of different dimensions above and below the slab, does SAFE stop its punching shear check?
RE: SAFE v12 punching shear
I hope you can find out in the SAFE folder with manuals and i believe that will give your answer.
My opinion is get the forces for punching shear and do the manual check. We are using SAFE v12 but still I find the some of the results different from manual calculation. It might be the punching area which is the problem.
Yes, that's what I decided in the end. I still hope CSI will actually update SAFE v12 and fix some bugs. I found that, as you thought, the punching area isn't always accurate. Sometimes, for some unknown reasons, SAFE would "ignore" the added thickness from a drop panel.
thanks
Newei, Have a great day ahead =)
AlphaXY
How do you check local and global bearing stress in SAFE for rafts? How do you check deflection? and differential settlement?
AlphaXY
I dont know if SAFE can do differential settlement and i will love to know if you get an idea.
z
In showing the actual bearing stresses (which should not be equal nor greater than the allowable bearing stress, qa) which should I use to view or check this? Deformed shape or slab stresses?
In Deformed shape where I can define the contour range. Is this where I can set the limits for allowable bearing stress or is this for settlement?
I am not sure if we can check settlement in deformed shape because there is a limits to be defined, but in other softwares we get the joint displacement to get the max and min settlement then subtract to obtain differential.
AlphaXY
