Feeder Speed for Coal mills.
I need some information on minimum feeder speed requirements for coal mills. Right now the minimum feeder speed on the mills is 20%. I would like to drop that to 15%. Could this create any problems when starting, or stopping a mill under normal operation? I could not find anything specific in NFPA 85.
RE: Feeder Speed for Coal mills.
1 To maintain a stable coal bed.
2 Maintain a max PA to fuel ratio in the PF lines for flame stability.
3 The PF piping system turndown depending of mill to fuel ratio control
These areas must be investigated to decide to reduce the feeder speed
We run 25% for minimum and move up quickly from there. Our burner flames are not stable (from the operator's point of view) without oil at that level.
What about your coal, Is your Volatile/coal ratio higher than 1.5 ?
