Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Within the first afternoon I found 2 of the 3 needed solutions, and the 3rd came to me over the weekend!..."
Geography
thepricedude (Structural)
26 May 09 17:14
I want to convert a time history record of an earthquake into a response spectrum.  I am aware of the theory behind this but would like to locate software that can do it for me without setting out to write something myself.  Has anybody developed something that they would bewilling to share, or is there any Freeware out there that you can recommend?
With thanks.
btrueblood (Mechanical)
26 May 09 19:46
Do you have access to Micrsoft Excel?  There is a fourier transform add-in that comes with the install disk...
electricpete (Electrical)
26 May 09 19:56
Shorter list:  What math software DOESN'T do FFT's.
rybose (Mechanical)
27 May 09 8:27
www.vibrationdata.com
It will cost you $40 for the subscription, but it has plenty of simple programs in matlab and C++.
FeX32 (Mechanical)
27 May 09 11:43
Here's one I just wrote for Matlab:
clear all;
fs = 1000;       % sampling freq.
T = 1/fs;
TM=3;
t = 0:T:TM;
x = cos(50*t)+2*sin(80*t+pi/3)+3.5*cos(155*t+pi/6)+4*cos(180*t+pi/4);        % example signal
data=x;
N=length(data);
Fmax=fs;
delta_f=(1/(TM*Fmax))*Fmax;
f = 0:delta_f:Fmax;
F=fft(data);
figure
plot(f(1:N/10),abs(F(1:N/10))),grid
title('FFT'); xlabel('Frequency (Hz)');ylabel('Amplitude')
Fe
FeX32 (Mechanical)
27 May 09 11:46
Should work for any signal 'x' as long as you remember to change the sampling frequency to yours. As well as the signal 'x' should be your earthquake time signal as well.
peace
Fe
SomptingGuy (Automotive)
28 May 09 5:20
The same code will run unmodified in octave, which is free.
- Steve
FeX32 (Mechanical)
28 May 09 9:15
Good point Steve. I just tried it. Works fine.
Fe
FeX32 (Mechanical)
28 May 09 21:09
Oh an don't forget to change 'TM' to your time signals length in seconds.
peace
Fe
1 Jun 09 5:00
All,
Just returned from vacation hence the late response.  Thanks to all who responded, you have all been most helpful.  I dont have Matlab but "btrueblood" can you tell me more about the Excel fourier transform capability?
With thanks
FeX32 (Mechanical)
1 Jun 09 10:43
Why not try octave? Its all done for you.
Fe
1 Jun 09 11:03
You need to install the Analysis Tookpack as follows:
Tools / Add-ins / check the box "Analysis Tookpack"
Then you can choose Tools/Data Analysis / Fourier Analysis
If you want to use VBA, you can also install the "Analysis Tookpack - VBA" tookpack which will give you access to the VBA "fourier" function.  Note that complex numbers are represented as stringes.
The limit for excel's FFT is 4096 points.
1 Jun 09 11:20
Another little thing you've gotta do to use Fourier in vba is (in the vba editor window) select Tools/References and check "atpvbaen.xls".  You don't have to worry about that if you are not using VBA to access Fourier
1 Jun 09 14:25
This all sounds very complicated.  I'm with FeX32, why not try a (free) environment designed for this kind of work rather than tailor your one and only hammer for this kind of nail?
- Steve
1 Jun 09 15:23
Oh, SG.  And deprive the gentleman from the wonderful learning experience presented?
Actually, the Excel function is fairly straightforward, if you are at all familiar with FT analysis.  It's limited in many ways, but I've used it before to get reasonably quick, cheap, usable data output.  Excel is less a hammer than a bloated, expensive, cumbersome swiss-army-knife and food processor all rolled into one.  That said, it's usually already installed on most machines, and most users are familiar with it.
FeX32 (Mechanical)
1 Jun 09 17:16
Octave is a more wonderful experience..... (more like a light saber compared to the tiny swiss army knife) smile
....and hell we even wrote the external m-code.. all you have to do is cut and paste.
Fe
FeX32 (Mechanical)
1 Jun 09 17:18
... its like trying to compare Linux to windows.....
hammer
Fe
Helpful Member!  tomirvine (Mechanical)
2 Jun 09 18:23
A Fourier transform and a shock response spectrum are two different calculations.  Yes, there are some roundabout, indirect, relationships between the two functions; but please consider them separate for now.
I have posted a shock response spectrum tutorial at:
http://www.vibrationdata.com/tutorials2/srs_intr.pdf
The tutorial is geared toward aerospace shock, but the principles and formulas are the same for earthquake shock.
The required input is a base acceleration time history.
Tom Irvine
2 Jun 09 20:08
Good point.  Also:
http://en.wikipedia.org/wiki/Shock_response
So it looks like you have to take the base acceleration TWF, input it into SDOF with frequency f1, damping d0, determine peak acceleration of the response r1, plot point (f1,r1)
Then repeat with frequency f2, damping d0, compute response r2, plot point (f2,r2).
2 Jun 09 20:27
... where f1 and f2 are the resonant frequencies of those SDOF systems.
FeX32 (Mechanical)
2 Jun 09 22:33
Now it comes down to whether the OP's time history is the time history of a structure or of just the earthquake itself.
Fe
FeX32 (Mechanical)
2 Jun 09 22:35
All in all. Good one Tom.
Fe
spongebob007 (Military)
4 Jun 09 15:57
FFT is NOT a response spectrum.  I use a program called UERD Tools to generate SRS curves.  I can also do it with NASTRAN.  If you really want to write your own program the math can be found in almost any vibrations textbook.
Close Box
Join Eng-Tips® Today!
Join Us             Close
