Selected Assemblies aren't Highlighting
When I select an assembly in any other .sldasm file, it highlights. When I select an assembly in this one, it does not. See attachment. Thoughts? Help?
Note: These assemblies are part of larger assemblies that do highlight (i.e. - 101 highlights, while 110 does not), but I've had this type of setup highlight before no problem.
RE: Selected Assemblies aren't Highlighting
Im not sure if e-drawings imports any options from the assembly. If so, the difference could lie in SW options (template)
Artem Taturevich
CSWP
