Form tools folder not updating
Hi there, I'm using SW2008 and have run into a situation where the folder that I put form tools in does not update. After making a form tool and designating the folder it's in as such I try pulling it in from the design library pane, but it's not there. Only when I close SW and start it up again does it appear. Has this happened to anyone else out there? Thanks!!
RE: Form tools folder not updating
So I'd caution about using features like this in the first place, unless you don't plan any edits or need to use the forms multiple times in multiple parts (saving time).
Jeff Mowry
www.industrialdesignhaus.com
A people governed by fear cannot value freedom.
My username--yeah, I thought "Most-Excellent-Theophilus" might be a bit over the top. I'm pushing it, as-is, with the shortened version.
Jeff Mowry
http
http:
