Copiying of Skech from One plane to other.
I am using UG NX-5.Is it possible to copy one sketch from one plane to other?If yes,what is the solution for that.I am not asking about the reatach option.Suppose i want that sketch in Front plane and in One inclined plane if possible with all the constaints.
Thanks in Advance
Thanks in Advance
RE: Copiying of Skech from One plane to other.
Use the Edit > Copy function
Then Edit > Paste
Set the expression transfer modes and select the external references. To make my life easier, I try to avoid making contraints external to the sketch where possible (I use a Datum CSYS to constain to) this makes the selection process far simpler.
John Joyce
Tata Technologies
1675 Larimer St.
Denver, CO
www.myigetit.com
NX3,4,5,6 Solid Works, Pro/e, Solid Edge
