Utility X/R and SC
Utility X/R and SC
when performing Arc Flash study inside a factory, 3p and 1p sc values are provided at that location by Hydro. Does this mean that I need to leave out x/r ratio at SKM and assume those values zero?
Since there is no utility impedance?
RE: Utility X/R and SC
Alan
"It's always fun to do the impossible." - Walt Disney
Entering x/r ratio will introduce another impedance which has already been accounted for.
My understanding is if the utility provides X/R ratio, then the fault level is at the substation and using X/R will result in Sc at the factory location. Is this right or am I missing something?
"X/R is a ratio of the reactive and real portions of the source impedance, says nothing about the magnitude of the source impedance"
isn't X/R representative of and impedance in series with an ideal supply voltage?
Z=(VL-L^2/MVA
MVA=1.73*Isc(3p)*VL-L
So if Hydro provide me with SC values at the factory , by accounting for X/R again ,I actually increase the impedance and therefore lowering the SC level downstream.
Also, the 'hydro'should have indicated that the SC value they gave you was 'symmetrical'. If the value was symmetrical; they did not factor the X/R.
3p=3 phase fault, all three phases short circuited simultaneously, symmetrical fault
1p=1 phase fault, sc between one phase and earth, asymmetrical fault.
If we are, then:
X/R defines peak current for all types of fault, not just asymmetrical, type of fault defines what is X and what is R.
To determine sc current magnitude, u need X and R magnitudes, not just X/R ratio. For 3p fault u need just direct sequence impedance, so if you have 3p sc current data provided, u can find Z upstream and then go downstream by adding Z. For 1p fault u need and zero sequence impedance Z0. sc current magnitude 3p/1p ratio depends on Z/Z0 ratio.
