ASME Section I external pressure calculation
Dear all,
In PFT-51.1.2, the code describes the method for evaluation of the maximum allowable external working pressure. In the case of a cylinder with definite pattern openings, what consideration should I use to consider these openings? Should I include the ligament efficiency?
Best regards.
Best regards.
