Alternatives to 446 SS
I'm looking for some magnetic stainless steel which could be used subsea (5000-15000ft) indefinitely. 430 for example is common but is worse with regard to seawater corrosion than 304.
I'm familiar with 446 which is a very high chromium flavor 400. I'm looking for others. Bonus points for a material I can get in a sheet metal form factor.
RE: Alternatives to 446 SS
htt
Can you get by with thin sheet?
Look at the super-ferritics, S44660 and S44735.
Plymouth Tube
Plymouth Tube
I have not failed. I've just found 10,000 ways that won't work." — Thomas Edison
_____________________________________
