Understanting the icl7107(adc with display)
Hi guys, I am attempting to understand the 200mV configuration of th icl7107 (fig 1) in the datsheet attached. My question is the analogue ground shorted internally with the power of chip? why is the reference voltage is connected between the 9V supply and the analogue ground?instead connected by the ground of the power supply?Thanks
RE: Understanting the icl7107(adc with display)
TTFN
From the data sheet: "The input can accept differential voltages anywhere within the common mode range of the input amplifier, or specifically from 0.5V below the positive supply to 1V above the negative supply"
Study the schematic diagram in figure 3. It answers all your questions. There is also explanatory text that is worth studying.
Gunnar Englund
www.gke.org
Why don't you just buy a ready-made voltmeter module? There are tons of them out there.
Benta.
TTFN
TTFN
There are three state of the symbol ,the Auto Zero,the Integrate State and De Integrate State.The symbol is used as the current flow or as an indication path of the current between each state, I think so. Did I understand well, tell me please.Thanks.
Gunnar Englund
www.gke.org
