Electrical / Insrumentation trays separation distance
Hello everybody.
I looked over at NEC and didn't find an answer.
Please point me where to find this information, minimun separation distance between electrical (power, lighting, control) cables and instrumentation (F&G, service, J1, J2, J3, ESD, SIS, Telecom, etc) cables in above ground instalations (trays).
Thanks in advance.
Best Regards.
MARCO
Thanks in advance.
Best Regards.
MARCO
RE: Electrical / Insrumentation trays separation distance
Because of the various susceptibilities and noise sources that abound you won't find a Standard. You may find some corporate or industry guidelines or rules.
Search in here for "cables separation control".
Keith Cress
Anything over 1000V must be separated. Below that, you're on your own - use company standards or best practices.
The NEC does require that all cables in a common tray, conduit etc must be insulated up to the highest voltage in use. So if you run 480 V circuits in the tray, everything else must be insulated to that level.
But itsmoked is very correct - the NEC is mainly a fire prevention standard, not an installation specification.
"The more the universe seems comprehensible, the more it also seems pointless." -- Steven Weinberg
Roy
The idea is not to run E&I cables in the same tray with a barrier but to use separate trays for each cable types but using the same support (same threaded rod in a hanging arrangement) and I don't know the separation distance between trays and since NEC doesn't have an answer I guess I'll just have to use 300 or 350mm.
300 - 350 sounds OK, the trays need enough spacing so you can get your hands in to lay the cables
Roy
Gunnar Englund
www.gke.org
Regards.
