design of weld
design of weld
design of weld
please explain depending upon ANSI pressure class, how to design a weld for pipe and weld neck flanges
RE: design of weld
This is not something that can be easily done in a forum.  You need to have someone with whom you can consult on a local basis.
RE: design of weld
Review ASME B31 Piping Code that is most applicable to your design and ASME B16.5. As mentioned above, get some help with this.
