Layout Hyperlink to latest drawing version file
Hi everyone!!       [  first time here :) ]
Im trying to set a hyperlink on a layout that opens the latest file of a certain drawing.
Ex.: C:/folder/folder/file.drw.250
But if i need to change the drawing for some reason, the version of the drawing gets to drw.251, witch means that the link that i´ve set before does not work anymore...
Any help on how to open the latest file version with an layout hyperlink?
Best Regards,
P.Fiúza
RE: Layout Hyperlink to latest drawing version file
Leave off the file version number. Link file.drw to your layout and let Pro/E resolve the version.
Ben Loosli
Hi looslib !
Thanks for that tip.
Actually i had already tryied that but i just forgot to put the last dot on the file name. see below.
       WRONG - c:\...\file_name.drw
       WORKING - c:\...\file_name.drw.
Can you imagine how stupid i felt?!
That little dot at the end is a major diference...
Thanks a lot for your time!
Well, this doesn´t work afterall..
i´ve tried to put it this way:
      c:\....\file_x.drw
      c:\....\file_x.drw.
      c:\....\file_x.drw.***
neither of these are working.
is there a variable on config pro that can influence hyperlinks?
