Drill 40mm thick Chrome Alloy Steel
Casn anyone recommend a tool maker that can produce a drill bit or combination bit for drilling into 40mm thick Chrome Alloy steel pipe to facilitate a thermowell?
I cant get anyone at the moment that can sort this problem?
RE: Drill 40mm thick Chrome Alloy Steel
Their holes won't make "reamer quality" finishes, but they are fast and adequate for a thermocouple hole. You'll need a way to clamp the mag-based drills to the pipe.
What diameter thermocouple?
