Constraints
Constraints
Constraints
I am trying to get a wheel to run along a surface with many different contours in it.  Is there any suggestions on how this is accomplished.
RE: Constraints
Assuming this is a contour derived from a spline curve, you should be able to apply a tangency constraint between the wheel and the surface, and have the wheel follow the surface.  Dunno about a very complex spline, I've only ever done this with "simple" splines that aren't very far off from ellipses.
If the contour is composed of many seperate geometric entitites, you may need to look at each entity seperately, i.e. you could only constrain the wheel to be tangent to one entity's surface at a time.
Good luck.
RE: Constraints
Along with what btrueblood said, you could create a spline surface on the contour that you want to follow. This would give you the smooth entity you need and you could then make it invisible when you are done constraining.
David
RE: Constraints
Is there any way to get it to run from one surface to another.  For instance from a curved surface to a straight surface that were not drawn as one face.
RE: Constraints
I think translational constraints might be what you want to look at but it has been a while so I can't explain it to you. Perhaps someone else can.
David
RE: Constraints
aardvark has it - look the term "transitional constraints" up in the help file.
RE: Constraints
If you have Inventor Professional with Dynamic Simulation there are more options.  Otherwise Transistional constraint.  Zip and attach what you have so far if you can't figure it out.
RE: Constraints
Thanks so much for the help everybody.  It works great now.
