EN36A carbursing core hardness
Can we acheive a core hardness of 40-45 HRC from carburising operation while achieving 60-63 HRC on surface on a EN36A Gear?
Normalising/stress relieving
then
carburising & quencing in oil
then
tempering
Is above mentioned a ideal sequence of the operations for EN36A?
then
then
tempering
RE: EN36A carbursing core hardness
The process sequence you listed is a standard one for producing gears with the properties you listed.
These links may help -
http://www.westyorkssteel.com/EN36.html
http:/
