repeatability and reproducibility in vibrations
Hallo everybody
I´m working on a project where vibration is measured on a production line (oil punps assembly) and I would like to do a R&R study, does any know how to make a repeatability and reproducibility in vibrations when the signal change in time and frequency? what parameter use: displacement, velocity, aceleration, time, frequency, PSD,etc?. Thank you for any advice.
Cheers
RE: repeatability and reproducibility in vibrations
I'd work in the same domain as your customer's spec - if they specify a max acceleration, from a time history, use that, if they specify a max peak psd, use that.
If this is for an engineering based analysis, I'd be inclined to use velocity psd. Analyse each peak of interest separately.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
