Methanol base timing
Hi all i just have finich my mitsubishi eclipse and i need advise regarding base timing for methanol.My engine is 2.4 l compresion 12.5 non intercooled. Injectors primery 1600cc secondary 2200cc gt42r turbo.I plan to run hi boost about 50 psi. Eny info will be gradly apreciate.
RE: Methanol base timing
Why such high compression AND boost with no intercooler.
I don't know how much you need to retard from stock. I don't even know stock boost, CR and timing. Also I don't know if you changed valve timing.
With all the unknowns, I can only guess you need to retard it a lot.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Ihave no room for intercooler.Iknow some guys push70  psi with no problem
Have you measured their boost compression and charge temp, or are you taking their word. Talks cheap.
We run 10:1 and 40# boost, Roots blower, no intercooler 36 Deg SB Chev, but intake valve closes 75 deg ABDC. We win races with that. There is not much margin for error and an error is a hole in a piston.
Pat
for site rules
temperature is over 175 deg @42 psi my timing is 10 degee.FR 4.1.Anybody know proper IGT for methanol?
I would say that you need to drop those charge temps drastically. Maybe consider pre compressor water injection?
MS
thanks guys
