Dimensions and notes disappear in break view
Sometimes when I do a break view on a drawing some or all of the dimensions and notes disappear.   When I un-break the view they are there but when I go back to the break view they are not visible.  Is there some way to resolve this?
RE: Dimensions and notes disappear in break view
What version and SP of SW?
What happens if you apply the break before applying the dimensions and notes.
I always break the view first then add dims.
Has been a bug in the past. Don't know about '09.
Chris
SolidWorks 08, CATIA V5
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
try this
Un break your view
then
fetch all the points from inside of the break to outside(like in case you have a note pointer inside move the pointer to outside somewhere.
then
break the view again.
Hope this helps.
Sorry forgot to mention using SW2007 SP3.0.  The biggest problem I'm having is that everything is already dimensioned and notes with pointers already placed.  All of these things fall outside of the break lines so its not a case of them not being there because they fell in the section where the break lines are.
I problem I usually have is with a drawing that I have breaklines on already and I need to go back and change something to it.  Sometimes the dimensions and notes will show up while the drawing is loading and once its finished they disapear.  Sometimes it is when I need to make a change to something and then everything disapers.  Is this just a bug in SolidWorks?
What graphics card and driver are you using?
It's an NVIDIA Quadro4 XGL with driver version 9.1.3.6
