High Frequency Impedance Meter
In all lightning system, the conductor are buried to the ground in a specific depth. The impedance of it is measured using da excitation. This technique is not strictly use when the conductor is diverting a high frequency sources to ground such as lightning current. What method is suitable to measured the impedance due to the lightning.
