Tech Specs for FM Line Stop and Bypass
Does anyone have a source for technical specifications for a line stop, tap and bypass of a sanitary sewer force main?
Any suggestions would be appreciated.
RE: Tech Specs for FM Line Stop and Bypass
Do a google search for section 15050. Here is an example:
http://www.mcwd.org/docs/engr/std_specs0805.pdf
You can also use the "Standard Specification for Water & Sewer Main Construction".
I've tried that. None found specific to FM Line stops and Bypassing. Most only speak to gravity bypassing manhole to manhole. Thanks though.
The link above has a water main tapping procedure that should be more or less the same as that for tapping a force main.
bimr,
Thanks for the help. It'll be a decent place to start. have a great weekend.
