Cam Changes for a De stroked Motor
I want to build a 500cc twin with a 75mm piston and 55.5mm stroke.
because of limited cams, My other options are to bias cam follower profile and rocker ratios. Can I do anything with either/or both of these?
The motor is vertical twin with 6" rod and 11.5 CR for a Land Speed Record
The original stroke was 88.9mm
The cam is @.04 .436 lift 312 D 106 LC
Int 50 BTC Ex 82 ABC
Int 82 BBC Ex 50 ATC
Rocker ratio stock is 1.13
I posted this on Speed Talk with no response So I may be in left field on this one.
Cheers
Thanks in advance
Cheers
Thanks in advance
I don't know anything but the people that do.
RE: Cam Changes for a De stroked Motor
I.e., piston to valve clearance might become a problem.
Mike Halloran
Pembroke Pines, FL, USA
Cheers
You are changing many parameters with the stroke change, that is if it was tuned ie designed for optimum before the changes. Someone with a good simulation program could get you close to what you need.
Oh well its not an engineering question anymore so I will stop.
Dicer
I have to play with the cams that I have, so I am not trying to redesign the cam but trick the valves into thinking there is a compatible cam driving them..
Cheers
Is it a twin cam. Playing with lobe centre seperation on a twin cam is safe enough so long as you have enough piston to valve clearance.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
These effects come about because the line of action of the follower becomes slightly offset from thr line of action of the cam. The offset essentially causes the circular motion of the lobe's flank and nose to become involved in the lift. The effect is usually described in textbooks etc. using a roller follower as an example - but it is much the same principle.
No matter what you do you cannot change the overall duration of the cam profile by manipulating the followers/rockers etc. You can change the lift by changing the rocker ratio but probably there is no need to (and expensive).
The 500cc engine will "see" the original cam as a bit "fiercer" than the bigger 800cc engine. I would have thought that this is what you want for a top-speed-only engine. I personally would use (or at least try) the cam and followers as they are. I also think the CR could go up quite a bit.
As other people have pointed out, make sure the valves/pistons etc. don't clash.
Good luck and try not to fall off at 200MPH.
Also, from the specs you list, are you measuring the cam at .040" lift? Are you saying the measured duration at .040" lift is 312°? Usually the accepted method of comparing camshafts is to measure them at .050" lift.
Larry
I will try to find out what a high performance cam profile would be so I know what I'm shooting for, and see how close I can get with all the trick I have available.
I probably could get a cam designer to profile a cam just for this motor but for some reason this has become interesting for me.
I think Bigvlad was talking about the push rod angle changing as I lower the head 2 1/4".
That brings up another trick in my bag (I don't know how it applies now) and that is to raise or lower the rocker pivot. I am going to remake the rockers anyways to change the ratio.
Also, are you sure about lowering the head 2 1/4" (57mm)? I would have thought 17mm would be about what you need.
I still think you should try the original cam(s) and not alter the rockers etc.
The rest is a change from a 150mm rod length to 100mm and I just remembered the compression height was shortened 15mm
with the new J&E pistons.
I have a 750cc bike that I took 18mm off the barrel and made new carbon fiber push rods not for weight savings but stiffness as I used the 32 valve Ford beehive springs.
I guess what I am saying I am not in new territory in the machining side of the project it just that when I make a mistake at work I write an ADCN and get it changed, but at home when I cut metal I can't afford a do-over.
Larry
I wasn't into the angle but as my cam followers are rectangular I was hoping to take the leading edge completely away hopefully change the ramp engagement angle to my lifter.
I have followed your post and read them with great respect it keeps me honest or at least pragmatic in my wonderland.
Thundair: A four-inch rod? - I've seen longer rods on lawnmowers.
