Gas Fired Generator
Gas Fired Generator
Gas Fired Generator
I am looking for a 10-15KW, Gas-Fired Continuous  Duty ( NOT STAND BY)  Electric Generator. Any Help? Who makes 'em?
Thank you
Fayaz
RE: Gas Fired Generator
Olympian makes gas generators starting at 9kW. You will need to contact your local Caterpillar Dealer for the Olympian line.
Onan also makes gas powered generators.  From about 3KW to 75KW, that I am aware of.  They build lots of these type for military applications.  If looking at surplus, be careful, because many are 400Hz instead of 60Hz.
Kubota is another possibility.  They supply lots of really heavy duty units to rental companies.
