Requirements for welding to outside of vessel
I have a small break vessel that has a bracket on the outside that needs to be moved inorder to facilitate installation. The vessel has already been hydro tested, and does not require PWHT.
My question is: Are there any specific requirements as per code that i need to be aware of in order to but off this bracket and re-attach it in a different location. The vessel material is 304H SS.
Thank you for any help provided, it is greatly appreciated.
RE: Requirements for welding to outside of vessel
