"Cannot open the file"
I am having trouble opening a part file. When I attempt to open the file I get the incident report: "cannot open the file:/cad/users/myname/CATTTempR18_customer/CNext01.roll/DOC4.CATPart". I have no idea what this DOC4 item is. Has anyone else had this problem? Thanks in advance
RE: "Cannot open the file"
Again, thanks for any help you can give.
I've never seen the doc4.catpart file in any of my errors, so I'm just going to have to try get a clearer picture of what's really happening...
Christian Bunes
http://www.plastal.com/
Apparently the DOC4 file is linked to my file. I am not sure how it got linked. I agree with Azrael that it may be a ghost link. Azrael, thanks for your suggestion. I will give it a try and get back with you.
You can isolate parts and kill links to documents that shouldn't be there too.
For more info on the CATDUA return codes, take a look at this: http:/
Be wary of Priority Level 1 codes as these may lead to data deletion.
Christian Bunes
In your case, it appears that a file ended up with a link (incorrectly I imagine) to a temporary backup file, that then clearly got deleted.
I don't know how then to solve your problem, but perhaps this information will point you in the right direction. More work with CATDUA is my best guess. I'm not quite an expert, but this is what I have seen in my experience.
Cheers,
Mark
