Vacuum breakers standard on fired boilers (eg those no vacuum rated)
dear all,
I am trying to get an undestanding of engineering approaches here.  We have  a boiler which is not vacuum rated but currently does not have a vacuum breaker.  The procedure is to open a vent when the pressure drops near atm pressure.  This boiler is cycled up and down every week while a waste heat boiler is turned up/down.
Should we invest in a vacuum breaker ?
or are those a bad device the spirax sarco web site seems to suggest they are common.. (on boilers that are not vacuum rated..)
is this true
