Problem Hiding Datum Planes
First, I tried to post this but it didn't go, so sorry for the double post if the other magically appears...
My problem is that I am no longer able to hide my primary datums with out affecting the associated drawing of the part or assembly.
Previously I would hide my automatic and user crated datums with the Display Datums button, and then hide the primary datums on the model tree.
Now when I do this my datums also disappear from the drawing views that I have placed them in. For example, I will have to reshow primary datum A in the drawing file if I hide datum A in the part file.
It's getting very annoying and I can't figure out why this problem has started up.
Any help would be appreciated.
Thanks.
Thanks.
RE: Problem Hiding Datum Planes
draw_layer_overrides_model yes
indrawing right click blank area properties-drawing options
what I didn't mention is that our IT guys reinstalled Pro/e on my machine and I forgot to save my config files before they did this...
anyway, got all my config options back. just takes a while to remember all the options since I don't use them very often.
guess i'll remember to keep a back up of my config and template files from now on.
David
I've also posted mine to forums including this one so I can always track down a post and get them back.
Michael
