Truly robust, waterproof, excellent pipe coatings?
We have a lot of carbon steel pipe running through pipe bridges containing liquid NH3.  We are constantly painting/repainting/repainting to maintain mechanical integrity and some of the areas require expensive scaffolding to get to.
Anyone have any experience with a coating other than primer/paint?  I've read of polymer coatings that are applied almost like paint.  Something that can handle expansion/contraction, sunlight, etc.  I expect it to cost more the first time, but if it lasts....
RE: Truly robust, waterproof, excellent pipe coatings?
Here is a neat process.  I've never seen it done in real life, and don't know if it would fit the spec.
http://www.xiom-corp.com/
The principal problem is that you are now maintenance painting on in situ pipework which does not offer the best conditions for maximising coating longevity.  A number of studies have shown that sealed thermal spray aluminium (TSA), when correctly applied, offers a significant durability extension compared to other coating systems.  If you can get a survey to confirm satisfactory application conditions and accessibility it should be a strong candidate.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
More info....
1)  Is something leaking onto the pipe ?
2)  Are you near the ocean, brackish water, industrial smoke area?
3)  Is the coatings failure at the "top" of horizontal runs, near flanges or valve stems ?
4)  What temperature is the pipe and is it subject to thermal cycling ?
5)  Is there coating failures under insulation ?
No one painting/coating system is best for all circumstances..
-MJC
