Voltage and current imbalance on VFD output
We are developing a dynamometer stand for durability testing of a hybrid vehicle driveline, which includes on-board PWM inverter and PM motor. Can anybody recommend a commercially available monitoring system which would detect voltage and current imbalances on inverter output? We can not use any inverter internal signals and must use an external monitoring provisions.
RE: Voltage and current imbalance on VFD output
For voltage(s), I use a low pass filter and a differential probe. Set the low pass filter frequency to 1 Hz. That will give you the V/Hz number directly and any change will be readily visible.
NI's LabView is relatively easy to build the monitoring functions in. I'm afraid that is the nearest a standard equipment you can get. Flexible and easy to extend when you need to.
Gunnar Englund
www.gke.org
Are you interested in the complex waveforms? I try to avoid them when checking motors and drives. But, of course, I need to look at them in detail when checking switching patterns and "modulator", which can be anything these days, mostly SW.
Gunnar Englund
www.gke.org
This is a good reference piece on the subject, albeit slightly biased.
h
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
Also, have you used a current probe with yours? I don't have one and have often wondered whether it would be worth the investment.
Yes I used a current probe, but not the one from Fluke. A friend of mine is the rep for AEMC and they make most of the current probes sold by everyone else, so I used a flexible one he got for me as a "sample"
http://
They aren't cheap though, I have to warn you.
Huh, funny that I never noticed (or paid attention to) the double image. Wish I had mine back so I could look at it again
If everything is perfect you will see a circle otherwise quite deviations quite easy to analyse. Many older papers on PWM AC motor control use this kind of display.
Current imbalance is much more likely and probably reflects imbalanced impedances in the leads and motor.
You brought an interesting point. The voltage and current imbalance measurement was a part of customer requirements to provide an early indication of potential e-motor problems during durability testing. We might limit our design to current imbalance monitoring only. I tend to agree that voltage imbalance would indicate inverter rather than motor problems.
