When exporting assemblys in NX5 to step. the step file to small
When ever I try to convert assembly drawings into one big step file(using NX5) the step file does not convert correctly. The size of the step file it creates it is like only 5k. How do I export an assebly to create on big step file.
RE: When exporting assemblys in NX5 to step. the step file to small
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
Creates huge honkin' files for me
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
Choose "selected objects",
then grab everything with a window and you should be good.
Works great for me.
J
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
File->Utilities->Customer Defaults->Gateway->General->Translator Directories &
for "Step files directory" Browse to "STEP203UG" folder in UG installation folder.
give OK, restart UG.
