sheet metal closed corner
I have a rectangular sheet metal part. I have done edge flange on four sides. Each flange is separate from another. How can I join the corner side of 2 nearby flanges?
Any help will be highly apppreciated.
RE: sheet metal closed corner
Reaper.
But instead of extending, I want to rotate that face and match with the other flange which is located at 90 degree angle.
I do not understand why they do not have the option for rotating the face.
Can you not reduce the length of one flange and add an Edge Flange to the adjacent flange.
Whichever way you do it, the faces cannot actually match or touch. There must be a gap if the part is to remain sheet metal.
