Copy Whole Sheet From One Drawing into Another Drawing???
Good after noon. I have a drawing with one sheet of the drawing exactly what I want, so I would like to copy it. I have a second sheet in a different drawing and I would like to paste the copied sheet into the blank sheet in the second drawing. I have tried CtlC and CtlV and nothing comes of it and I have also tried using the menu items, copy & paste, as well. Is there any way to do this? It would save me several hours of time if I could. Thank you in advance for any assistance with this.
RE: Copy Whole Sheet From One Drawing into Another Drawing???
You cannot copy the sheet itself, but should be able to copy all the views and notes therein.
If the sheet format exists, you should be able to call it into the new blank sheet via RMB > Properties.
