LPILE question
LPILE question
LPILE question
I am getting very large NEGATIVE deflections for my pier lpile runs when using a pinned head connection (hpile will be encased in concrete approx. 22ft above ground surface).  Can I use a fixed-head connection in this case.  If I use a pinned head connection, what could I use as a control option, how much deflection should I allow?
RE: LPILE question
"(hpile will be encased in concrete approx. 22ft above ground surface)"
How could it be pinned?
RE: LPILE question
How much is the embedment length of the pile (into concrete)?
RE: LPILE question
embedment 22 ft into concrete.
RE: LPILE question
sorry, i was unclear, it will be encased in the concrete from ground surface to 22 ft above ground surface.  So fixed head then?
RE: LPILE question
Fixed.
RE: LPILE question
Reason: The angle between the pile and the bottom face of the mass concrete will stay constant.
RE: LPILE question
thank you very much
RE: LPILE question
My pleasure, if that solves your problem.
