DocMgr API help - open, whereused, replacereference, save, close
Hi. I am trying to write a stand-alone app that will replace references in an assembly and then save the doc and close it. I am having issues with replacing the references and then saving. here is some of my code:
For Each folder In My.Computer.FileSystem.GetDirectories(DIR)
            toolno = UCase(Microsoft.VisualBasic.Right$(folder, Len(folder) - (1 + Len(DIR))))
            i = -1
            For Each file In My.Computer.FileSystem.GetFiles(folder)
                filename = Microsoft.VisualBasic.Right$(file, Len(file) - (1 + Len(folder)))
                If UCase(filename) = "MAKETIFF" Or UCase(filename) = "HP1050CPRT" Then
                    My.Computer.FileSystem.DeleteFile(file)
                ElseIf UCase(Microsoft.VisualBasic.Left$(filename, 4)) = "BEAD" Then
                    i = i + 1
                    ReDim Preserve newname(i)
                    ReDim Preserve oldname(i)
                    newname(i) = toolno & "_" & filename
                    oldname(i) = file
                    swdoc = tapp.GetDocument(oldname(i), SwDocumentMgr.SwDmDocumentType.swDmDocumentUnknown, True, ie)
                    src = tapp.GetSearchOptionObject
                    src.AddSearchPath(folder)
                    If swdoc.WhereUsed(src) IsNot Nothing Then
                        assembly = swdoc.WhereUsed(src)
                    End If
                    swdoc.CloseDoc()
                    My.Computer.FileSystem.RenameFile(oldname(i), newname(i))
                    End If
            Next
            f = 0
            If i > -1 Then
                swdoc = tapp.GetDocument(assembly(0), SwDocumentMgr.SwDmDocumentType.swDmDocumentUnknown, True, ie)
                Do Until f = i + 1
                    Call swdoc.ReplaceReference(oldname(f), folder & "\" & newname(f))
                    f = f + 1
                Loop
                i = 0
                saved = swdoc.Save()
                swdoc.CloseDoc()
            End If
        Next
any help is greatly appreciated.
Brad
RE: DocMgr API help - open, whereused, replacereference, save, close
bOILERbRAD,
I do not know the answer to your question.
Are you using SolidWorks Document Manager API SDK, which requires an access key?
Standing
SolidWorks Pro 2009 x64, SP3.0, PDMWorks Workgroup, SolidWorks BOM,
HP xw8600, 64-bit Windows Vista Business, Service Pack 1
Intel Xeon CPU, 3.00 GHz, 16 GB RAM, Virtual memory 166682 MB, nVidia Quadro FX 4600
I think when you replace a reference with SWDM, the change is automatically saved.  You do not need to open-save-close.
Thanks for your quick replies.
Standing,
Yes I am using the Document Manager SDK (I have a key).
Tick,
If I do not open the part with the SWDM, how does VB know in which part references are to be replaced?
I got it figured out. Apparently the refrences are case sensitive... DOH!
Thanks for your help anyways!
