Error Opening an Assembly
NX 3.0.5.3
Trying to open an assembly model, I receive the following error : "Internal error: an attempt was made to access an attribute not in the relevant class"
I can open the top level drawing file (using the no components option). And, I can open all of the components themselves. Just not the assembly model.
Any clues as to what I can do to fix this ?
Specialty Engineered Automation (SEA)
http://www.sea4ug.com
a UGS Foundation Partner
RE: Error Opening an Assembly
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
I would suggest speaking to GTAC, although they'll probably suggest checking this on NX4 or above (NX3 is no longer supported)
Best regards, NXC
This is my first post at this forum. Have been reading it a while and found some good tips.
Just wonder what do you mean with "running a part cleanup"
I use NX4 and also have an assembly that gives me problem.
I can open the part as normal. But, if I do an output cls file. It takes about 2 min before it finish. Same if I save the file.
And if I try to shut down NX. My computer stop responding.
This is really an issue that you need to take up with Siemens support - There are a number of calls on the system that have been logged as PRs, these are still being investigated by Siemens, they're going to be in a better position to advise on this occasion.
All you'll need is your sold-to details, Siemens will do the rest.
Still waiting to hear back.
Suresh
www.technisites.com.au
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
