Quadrature squarewave generator
3
I need a CMOS circuit that will give me quadrature squarewave ouputs. Any suggestions?
RE: Quadrature squarewave generator
A PIC is the standard solution. Their 8-leggers come to mind. What frequency or frequency range do you need? There are lots of app notes on the web. Make google your friend.
Gunnar Englund
www.gke.org
You really want a 2-bit gray code generator.  Xilinx has a nice N-bit generator VHDL template in their ISE software that is a free download:
Gray code w/ CE and async active high reset
-- Usage of Asynchronous resets may negatively impact FPGA resources
-- and timing. In general faster and smaller FPGA designs will
-- result from not using Asynchronous Resets. Please refer to
-- the Synthesis and Simulation Design Guide for more information.
<next_binary_count> <= <binary_count> + 1;
process(<clock>,<reset>)
begin
   if ( <reset> = '1') then
      <binary_count> <= (others => '0');
      <gray_count> <= (others =>'0');
   elsif ( <clock>'event and <clock> ='1') then
      if <clock_enable>='1' then
         <binary_count> <= <next_binary_count>;
         <gray_count> <= (('0' & next_binary_count(<width-1> downto 1)) XOR <next_binary_count>);
      end if;
   end if;
end process;
You can simplify this down to a two bit counter and a couple of XOR gates if you want it in CMOS hardware.
John D
You may get perfect pulses of up to 200kHz with a PIC 10F200, SMD (SOT-23) pkg.
