Classification by Table B4.1 + Chapter H
I began working with AISC Specification (ANSI/AISC360-05) and would like to ask you for advice. I have problem with slednerness checking and understanding Chapter H.
Example: Rolled W profile bending about major axis combined with tensile force.
Process of design:
There is a "Chapter H - Design of members for combined forces..." where we need to compute: - "Allowable tensile strength - " Pc"
- "Allowable flexural strength - " Mc".
To compute "Pc" : Chapter D must be used.
To compute "Mc": Chapter F must be used. At first, we have to check slenderness of flange/web and than compute "Mc" according to F1,F2,F3... and others.
question 1)
Is this procedure correct??
If yes :
There are cases for slenderness check in the Table B4.1:
Case 9 - Flexure in web
Case 1 - Flexure in flange
Now I am going to check width/thickness limit for compute "Mc" value. As I said there is a moment only about MAJOR axis.
questions )
How to use Table B4.1 for combined forces?
Should I used Case9 and Case1 both together for slenderness checking? Or it depends on stress character in flanges e.g. both compressed; both tensile; one tensile + one compressed?
Thank you for your help and sorry for my english grammar.
P.
Process of design:
question 1)
If yes :
questions )
P.
RE: Classification by Table B4.1 + Chapter H
1, If combination "Tension + Flexure" produce fully tensile profile. Is it necessary to use Case1 and Case 9 if resultant is only tension?
2, If combination "Tension + Flexure" produce compression in one of flanges?
Please apologize me for probably simple questions but Im novice in AISC Code.
Soo, is there any difference between Example 1 and Example 2 how to classified them in case of Chapter H ?
Thank you
P.
http://f
Thank you in advance
