Reaction moment/Free body moment question
See attached .jpg's.  I have a part with a fixed constraint on the cylindrical face and applying a normal force of 5 lbf. on the extreme edge of the handle (see setup). The handle is 8 inches from the edge to the center of cylinder, therefore inducing a 40 in-lb torque around the axis.  When I view the results for either reaction moment or free body moment I get the following (see list results).  I have tinkered with all the options to get the result of 40 in-lb on the axis, but no luck.  Any suggestions on what I'm doing wrong?
Thanks in advance
RE: Reaction moment/Free body moment question
Looks like all you did was constrain the cylindrical face to be fixed.  This would not yield a torque around the axis.
Constrain the face relative to the axis with zero rotation or axial movement.
I ran this on my own.  The results you get are consistent with a fixed constraint.  Change the constraint to "Use Reference Geometry" w.r.t. the axis, and constrain all 3 DOFs (radial, axial, rotational).
w.r.t. = "with respect to"
Tick,
Can you send me a screenshot of how you are setting this up and the results screen?
Thanks.
Tick,
Thanks for attaching the part.  I still can't get the results I'm expecting under reaction force.  Still looks like the list results .jpg I first sent.  I dunno....
Thanks for your help.
