Changing material property half way
I'm doing a simulation that is broken into two time steps (think of temperature ramp up and down). I want my material to change some of its properties at the transition (e.g. for T=0 to 1, expansion CTE is 100, and for T=1 to 2, expansion CTE is 200).
How can I do this in ABAQUS/CAE? I've split up the simulation into two time steps and am changing loading (temperature field) in the second step. I can't simply do two independent simulations with different initial conditions since I'd like to keep the state of my elements when the first time step finishes.
Thanks in advance.
Thanks in advance.
RE: Changing material property half way
In CAE it can be done by Predefined Field->Other->Initial State.
